Failed to connect to the specified server
7927
8
02-22-2012 02:47 PM
FarhadNavaei
I'm trying to attach Mongomery.mdf data from Developerkit10.0 samples (C:\Program Files (x86)\ArcGIS\DeveloperKit10.0\Samples\data) into my database to be able to publish MontgomerySimple.mxd as a service.
I have ArcGIS Server 10.0 and MS SQL Server 2008 R2 Enterprise Edition. Although I converted the database from SQLEXPRESS to SQL Server and define the required user name and credentilas, I cannot connect to the database in ArcCatalog (Database Connection). When I click the "Test Connection" button in the "Spatial Database Connection Properties" form, the following error pops up:
"Failed to connect to the specified server. Underlying DBMS error [Unkown errorNo extended error.]
I have another Spatial database, which is created on the same server and works fine.
Anyone has any ideas what the problem might be?
FarhadNavaei
OK, I was able to start the former service. I just used sa user instead of sde user in the Creting service wizard. It deleted the old service and recreated it again and then I was able to start the service in command prompt. I don;t know if the sde service should have any previalges that I have missed, but if it's ok to create the service with sa username, I'm OK now.
Thank you
JakeSkinner
Esri Esteemed Contributor
Hi Farhad,
Did you change the compatibility level from SQL Server 2005 (90) to SQL Server 2008 (100)?  You can do this by right-clicking on the database in SQL Server Management Studio > Properties > Options.
Also, the database appears to be authorized for ArcGIS Server 9.3.  Be sure to re-authorize this for ArcGIS Server 10.
FarhadNavaei
Hi Jake,
I did  change the compatibility level, but I'm not sure about the authorization process. Should I run the ArcSDE Post Installation for that?
Thank you
JakeSkinner
Yes, choose 'Custom' on the first dialog and then specify only the option to Authorize ArcSDE:
[ATTACH=CONFIG]12208[/ATTACH]
Follow the rest of the wizard to complete the authorization.
FarhadNavaei
I did. It didn't work. Now, even my old geodatabase doesn't connect. is that because of creating ArcSDE service? Did I miss anything?
Please advise.
JakeSkinner
The wizard shouldn't have prompted you to create a service, but it won't matter if you created one.  What errors are recorded in your sdedc_SQL Server.log file?  This is typically found at C:\Program Files\ArcGIS\ArcSDE\sqlexe\etc.
FarhadNavaei
The following is the error in sdedc_sql_server.log
db_execute_sql Execute Error (229).
IDBInitialize::Initialize Failed
CAN'T OPEN INSTANCE: sde:sqlserver.
Spatial Engine Connection Failed (-9).
Cannot Get Access to Instance sde:sqlserver
Please see the following image. I was trying to start the first service, which I had from past, but it didn't work.
FarhadNavaei
[ATTACH=CONFIG]12312[/ATTACH]
FarhadNavaei
Thank you
