Failed to Connect to Database Server Error, Add Database Server help
6857
07-20-2012 06:51 AM
ClintonCooper1
Hello,
I am at wits end.  I installed SQL Express Server (Workgroup) on our server (RTA-GIS).  However on my local computer through ArcCatalog Add Database Server , I cannot connect to SQL Server and I get the error:  Register Database Server: Cannot connect to the database server, Failed to connect to the database server. Operation is not allowed when the object is open.
I have followed the installation instructions of SQL Server Express to a 'T'.  I have installed and run SQL Server Management Studio, and have made sure I can connect remotely, all TCP Ports and Pipes are enabled, All services are started (except SQL Server Agent - I cannot get that one to start).  Pretty much I have tried every trick and tried every tip and nothing has worked.
BenLin
Hi Clinton,
Have you tried using the port number for the SQL Server Express instance within ArcCatalog Database Server connection?
- goto SQL Server Configuration Manager, check TCP/IP dynamic port number that you have used for your current SQL Server Express instance, for example, in IPALL if you see the TCP Dynamic Ports as 8774.
- then from ArcCatalog, add Database Server as following:
   sqlserver_machine_name,8774
Ben
BenLin
Hi Clinton,
Ben
MarkNorbury
Ben,
Thanks for the response.  That's been helpful to me, as I was getting the same issue.
Mark
by Anonymous User
Not applicable
I ran into a similar issue on my end and wanted to add some information in the event that someone has my experience. In my case, I had ArcMap opened when I installed SQL Express workgroup as part of the 'Database Server Workgroup' installation (this was for ArcGIS 10.4.1; however, I suspect that this feedback applies to probably most versions).  After the installation, I tried to connect ArcMap to SQL Express using the database server, but received the same error message being reported in this thread.
I navigated to the TCP Dynamic Port and there was no special port number assigned (the default 1433 was being used as reported by documentation I found online for figuring out how to find the TCP information).
After a bit of time, I tried closing ArcMap and re-opening it (thinking that ArcMap was not seeing the new service on my Windows machine).  After I did this and tried to connect to my SQL Express instance, it worked without issue.
I wanted to add this as another item in case someone falls into this small trap and spends a lot of time troubleshooting (perhaps Esri can write a check on the installation script to make sure no ArcGIS for Desktop software is up and running during the installation?).
