ExtractByMask Error
2821
04-18-2010 05:15 PM
WentaoChe
ExtractByMask does not work for the following Python:
import arcpy
arcpy.CheckOutExtension("spatial")
tif = "H:\\Test-20100419\\t.tif"
shp = "H:\\Test-20100419\\A27401_05.shp"
out_raster = "H:\\Test-20100419\\ttt.tif"
out = arcpy.sa.ExtractByMask(tif, shp)
out.save(out_raster)
Error message:
  File "H:\Test-20100419\test.py", line 6, in <module>
  File "C:\ArcGIS\Desktop9.4\arcpy\arcpy\sa\Functions.py", line 1210, in ExtractByMask
    in_mask_data)
  File "C:\ArcGIS\Desktop9.4\arcpy\arcpy\sa\Utils.py", line 67, in swapper
    result = wrapper(*args, **kwargs)
  File "C:\ArcGIS\Desktop9.4\arcpy\arcpy\sa\Functions.py", line 1204, in wrapper
    out_raster)
  File "C:\ArcGIS\Desktop9.4\arcpy\arcpy\geoprocessing\_base.py", line 438, in <lambda>
    return lambda *args: val(*gp_fixargs(args))
arcgisscripting.ExecuteError: Failed to execute. Parameters are not valid.
ERROR 000879: Output raster: The length of the stack base name in H:\Test-20100419\Extract_t1 is longer than 9.
Failed to execute (ExtractByMask).
I set the output raster as a TIF not a Grid Stack, I can not understand the error message "The length of the stack base name is longer than 9." This is not the case.
There is no any problem when I use ExtractByMask Tool in ArcToolbox.
Best regards,
Wentao
KKC, Tokyo, Japan
RyanDeBruyn
HI Wentao
There seems to be an issue with the name of the temporary raster that is created by the tool. By default you must have a file based scratch workspace set so the format is attempting to create a grid stack(limit 9 characters).
Try to set a file geodatabase as your scratch workspace there will not be a name restriction.
arcpy.env.scratchWorkspace = "c:/data/myfilegdb.gdb"
out.save("C:/output/final_ras")
Thank you for your input, we will work to remedy the error.
-Ryan
ESRI Spatial Analyst Team
WentaoChe
Hi Ryan,
Thank you for your reply.
I tried to set scratch workspace and worksapce to :\Test-20100419\myfilegdb.gdb, both are failed.
Herre is the error message:
  File "H:\Test-20100419\test2.py", line 19, in <module>
    in_mask_data)
    out_raster)
arcgisscripting.ExecuteError: ERROR 000875: Output raster: H:\Test-20100419\myfilegdb.gdb\Extract_tif1's workspace is an invalid output workspace.
ERROR 000581: Invalid parameters.
Wentao
PeterProkein
This problem persists in Arc10 Build2414.
MichaelRichey
For what its worth (a little late to the game from the original post). I'm replying since I also recently received similar error messages when running "Extract By Mask" in a Python script (ArcDesktop 10.3.1). In my particular instance I am referencing a single DEM and selecting multiple polygons to create unique rasters from each polygon. After realizing that a temporary file is created each time the "Extract By Mask" command is run, executing the save command allowed the passing of a variable with a unique name, eliminating the error messages, allowing the script to create the intended output(s). I also specified a scratch workspace.
script Example:
env.workspace = "//w63-atlas/Stormwater/Waterways/Structure Flood Severity"
bslash = "\\"
Raster = bslash+"\\w63-atlas\Stormwater\AMEC\CLAY\TOPO\DEM\claydem.gdb\claydem"
arcpy.env.scratchWorkspace = "//w63-atlas/Stormwater/Waterways/Rasterdatasets.gdb"
tile = raw_input("Enter FEMA TILE : C4, C5, C6, D4, D5, D6, E5, E6, F5, F6, G5, or G6: ")
prefix = "Export_"
suffix = "_Culv*_1.shp"
depiwant = prefix+tile+suffix
fcList  = arcpy.ListFeatureClasses(depiwant)
arcpy.AddMessage(Raster)
for i in fcList:
     Culvnum = i[14:-4]
     rasnew = gdb+"/"+tile+"rz"+Culvnum[:-2]
     outExtractByMask = ExtractByMask(Raster,i)
     arcpy.AddMessage(outExtractByMask)
     outExtractByMask.save(rasnew)
     exit
