Extract Min/Max elevation from DEM?
1701
06-18-2013 12:21 PM
TomKearns
If I create a polygon and use it to run Zonal Statistics over the DEM (as the input raster) will I end up with accurate min and max elevations?
Rephrased: Are DEM's accurate elevation measures or are they scaled numbers (not measures in meters) assigned to show relationships?
Thank you in advance.
curtvprice
I am using a 1 arc second, 30M resolution DEM.
Another way to ask my question would be "do I need to manipulate a DEM to convert it to real measures".
The metadata (or readme files) that accompanied the raster data should tell you what the z units are. If this is downloaded NED data from the USGS National Map,  the z units are in meters.
The elevation data from National Map is delivered in geographic coordinates. If you are doing analysis that involves measurement of distances or areas, before you start the analysis you should project the raster to a coordinate system that will support your analysis (for example, UTM). .
curtvprice
This totally depends on your DEM dataset. For example, sometimes elevation datasets are shared using centimeter values so they can be stored as integer (for better compression) while still preserving .01 meter precision.
TomKearns
Thank you for the reply.  I am using a 1 arc second, 30M resolution DEM.
Thanks, again.
curtvprice
TomKearns
That is exactly the help I needed.  Thank you.
