EXTRACT BY ATTRIBUTE
2663
06-27-2016 03:41 AM
FaeezaFortune
Hi there,
I want to extract open water surface's using Xu's (2006) MNDWI.
Essentially, for Landsat 8, I have done the TOA correction, this was followed by the MNDWI calculation- using the Ratser Math tool. Everything worked fine, until I got to the point where I needed to extract the cells containing water (i.e. cells with the value >0). To extract the water, I used the Extract by Attribute tool. The results turned out blank. I have no idea what I'm doing wrong.
Please help.
Thanks.
Faeeza
DanPatterson_Retired
no need to triple post... follow the thread here EXTRACT BY ATTRIBUTE
