Export XML Workspace Document
2820
01-17-2012 11:29 AM
TedCronin
So, I kicked this tool off at 10:55 am on a 500 MB File GDB, and at 1:30 PM it is still going, so is this expected to take this long for a 500 MB file?
Executing: ExportXMLWorkspaceDocument C:\beta\GDB\TestTol.gdb C:\beta\GDB\TestXMLDoc.xml DATA BINARY METADATA
Start Time: Tue Jan 17 10:55:53 2012
Exported to C:\beta\GDB\TestXMLDoc.xml:
What is weird is it is saying Exported, should it say Exporting...  I would also expect something to be printed after the : like some sort of progress, since the colon I think denotes that something will be printed to the tool dialog.
TedCronin
Killed it, need to do other things.
...TestTol.gdb [File Geodatabase]
...Foobar
......AssessorGIS_ACR_GIS_ParcelLines
......AssessorGIS_ACR_GIS_Parcels
......aoi
......Foobar_Topology
ERROR 999999: Error executing function.
Cannot register as versioned on this database.
Cancelled function
(ExportXMLWorkspaceDocument) aborted by User.
Failed at Tue Jan 17 13:45:04 2012 (Elapsed Time: 2 hours 49 minutes 11 seconds)
Problem I see is that this was a file GDB so, why an error that says Cannot register as versioned on this database. �??
JasonPardy
Ted,
Are you able to export this same geodatabase using the wizard in ArcCatalog? Is it possible to get the geodatabase or perhaps, you can bring it to holistic testing next week?
Jason
TedCronin
You continue to surprise me, Jason.  Aren't you one of the python wizards, is this one of your tools?  I can retest here, and bring along. or upload.  Either way, whatever is easiest.  Trying to hit gp tools this week, so I can focus for next.
