Export Mosaic Dataset Footprints
1134
10-11-2010 11:11 PM
PCMPCM
I need to export mosaic dataset's footprint, but the Copy Feature Tool doesn't work. It does not accept the mosaic dataset as input while it works with raster catalog.
Thanks
Fabrizio
RobertBerger
Can you check if it works when the mosaic dataset is a layer in ArcMap? Do you then have access to the footprint layer?
Robert
PCMPCM
Yes if I do export from ArcMap Layer it works. If I select Footprint from the table of content and with right click I do export in a feature class I can get the Footprint Layer in the GDB.
No way from the geoprocessing tools.
Fabrizio
JieZhang
It's actually doable through the GP tools.
Suppose you are working in pure scripting environment.
First, you will need to use the Make Mosaic Layer tool, make a mosaic layer from a mosaic dataset in your GDB.
Then you can call the Copy Feature tool, just specify the input as <MosaicLayer>\Footprint, then it will work.
Jie
