Export Domains to spreadsheet
726
11-24-2010 08:29 AM
by Anonymous User
Not applicable
Does anyone know a tool that will help me export all tools to a table/spreadsheet? (for Arc10)
I used to use Geodatabase Reporter, but there is not a version for Arc10.  The domain-to-table works well enough for a single table, but not really for a gdb w/ 250 domains in it...
anthonysanchez
Hello,
I'm not aware of any tools but I do know that they are now stored in xml for you to grab and parse yourself.
for oracle:
range domains:
SELECT name,definition FROM SDE.GDB_ITEMS_VW
where type='{C29DA988-8C3E-45F7-8B5C-18E51EE7BEB4}';
coded value domains:
SELECT NAME,DEFINITION FROM SDE.GDB_ITEMS_VW
where type='{8C368B12-A12E-4C7E-9638-C9C64E69E98F}';
You may need to use sqldeveloper or some other tool that can display the xml for you.
-Anthony
BruceHarold
Esri Frequent Contributor
Hi
ArcPy Describe properties include a Python list of domains for any workspace which you could loop through the Domain to Table GP tool and make your tables.
Regards
