Exploratory regression tool throws error 000641
1598
06-28-2024 12:28 PM
Murtaza_Mir
I am using ArcGIS Pro 3.2
I am trying to use the Exploratory Regression tool but whenever I use the tool on a Feature Class, it throws the ERROR 000641: Too few records for analysis. This tool requires at least 5 feature(s) to compute results.
My Feature class has more than 70K records and 8 independent variables for Candidate Explanatory Variables field. I also ensured that I have no NULL values. But even then, I am getting this error repeatedly. Any idea what would be wrong?
Thank you
Murtaza_Mir
I believe I figured out the issue. The Geometry attributes of my data are erroneous. Even if we don't select them as Candidate Explanatory Variables, it will still result in errors. Just ensure that the geometry based columns are not erroneous and the tool should work.
Murtaza_Mir
