Exceptions been thrown when reading a "Double" column
1246
01-13-2013 04:03 PM
MaoEdgar
I've been suffered by a strange problem, I'm using FileGeoDatabase and reading a table, but the exception is thrown when getting the value, please see the sample from the attachment, can anybody help on this?
Regards,
Edgar
by Anonymous User
Not applicable
Original User: vangelo
Posting uncommon binaries in times with zero-day vulnerabilties in the news isn't
the best way to get help.
You'll likely find more assistance if you provide the version of software involved
(including whether you're using ArcGIS or the file geodatabase API), the programming
language in use, and the smallest possible code sample that exhibits the problem
(as a Code block in the message).
Then again, the ArcObjects or Python forums would more appropriate for ArcGIS
programming issues, and File Geodatabase API more appropriate for FGDB API
problems.
- V
by Anonymous User
Not applicable
problems.
- V
MaoEdgar
Thanks for your help on this, I've posted a new thread in the FGDB API forum.
Regards,
Edgar
