Euclidean Distance/Output Coordinate HELP!
1032
06-15-2012 09:34 AM
ElenaSava
Hello All,
I am trying to run a model for a work project that I am doing. Unfortunately, I am new at this and I have come across a problem that I cannot seem to understand what is wrong. I am trying to run the Euclidean Distance tool with the environments as seen in the document that I have attached. When I run the Euclidean distance tool with all four environments it shows that the model is running but there is no progress at all. ( I let it run for over an hour...no results) I went back and tested the Euclidean distance tool with each environment separately, it ran just fine except when I tested it with the 'Output Coordinate'. I don't understand why this problem occurs. Does anyone know how to fix this?
Thanks in advance
Elena
