ETL Tool
2861
6
02-25-2014 08:38 PM
Sehrish_IrfanSiddiqui
Tell me please how can I create reader feature type in FME Workbench??
SafeTeamResourceCenter
Please see this help article... this will help you add a Reader and how to add feature types.
http://docs.safe.com/fme/html/FME_Workbench/Default.htm#adding_source_datasets.htm
But if you are new to FME I'd recommend visiting this link and signing up for our free training
http://www.safe.com/learning/training/.
There is also free resources at the link above so you can start learning FME... on your own schedule.
We have lots more on FME Desktop and FME Server at the FME Channel on youtube.  But probably the Training is what you want to start with.
If you continue to have issues with FME please visit us at fme.ly/support and submit a support ticket.
Steve at Safe Software
I have been trying to Add reader in FME workbench but it does not work. It give error that "the Design Files does not exist". I have tutorial data, tutorial data is working. Please tell me how can I create data and how can I identify the whole tool depends on which field that is important in processing and its also varies from one to another.
Please contact us www.safe.com/support and we'll work through this with you from there.
SteveatSafe
ThozamaDyonase
How can you get a GPX reader on the list of readers in Version 10.2.1?
BruceHarold
Esri Frequent Contributor
Hi
GPX isn't supported at 10.2.1, it will be supported at 10.2.2.
You can use the core tool GPX to Features in the meantime.
Regards
ThozamaDyonase
I used the spatial ETL tool in ArcGis 10.1 but I received the attached error. What could be causing it and how can I solve it?
