Esri Icon Key
6429
7
10-21-2016 02:20 PM
DaleKerkvliet
Hi..Is there a key to all the icons used in ArcGIS and ArcCatalog?
By "icon" I mean the graphic found beside the different file types such as the rectangle with three dots for point features, boxes for shapefiles and diamonds for geodatabases.
Thanks!
ChrisDonohue__GISP
Wait, found it.  Check out the full list at this link:
FAQ: What do the icons in ArcCatalog represent?
(see above link for all the icons - this is just the first part)
Chris Donohue, GISP
ChrisDonohue__GISP
I don't know if there is a single source for all the icons, but many of them are depicted and labeled in the several help sections for ArcCatalog.  This will require a bit of reading and scrolling around, though.
ArcGIS Help (10.2, 10.2.1, and 10.2.2)  A quick tour of ArcCatalog
ArcGIS Help (10.2, 10.2.1, and 10.2.2)  Making connections in ArcCatalog
ArcGIS Help (10.2, 10.2.1, and 10.2.2)  The Catalog tree and item properties in ArcCatalog
For the ones that are not depicted, one can try creating items in a test environment and see what icon appears.  For example, try making a File Geodatabase and observe what icon ArcCatalog gives it.  Then make a Feature Dataset within the File Geodatabase.  Then Make a point Feature Class, etc.
Chris Donohue, GISP
ChrisDonohue__GISP
Chris Donohue, GISP
DaleKerkvliet
Thanks Chris!
LaurenLumHee
I looked through that list, but I didn't see anything that looks like the icon I've noted with this red arrow. Ideas? icons.PNGicons.PNG
LaurenLumHee
Also the icon I noted above acts as if it's a feature class. Really not sure why the icon appears that way.
George_Thompson
Esri Notable Contributor
That is typically a table / view that is NOT registered with the geodatabase. The client thinks it may be a spatial table but is not sure.
If you double click the layer it will show up with geometry type or table icon.
--- George T.
Frank_SA
I'm wondering if there are any resources that show the ArcGIS icons currently used in Pro and what they mean.
A lot of them look similar to their ArcMap counterparts, but I'm sure there's some new iconography as well.
(sorry if it is bad manners to revive such a old thread...Edit: Doh the link is broken, kudos for uploading the image into the thread tho!)
