Error When Validating Topology
3463
03-10-2016 11:22 PM
Nor_AfizahMohamad_Kamil
Dear Arcgis user,
I have questions. I got error when I validate topology. The error is shown below:
The rules that I have been used is Must Not Overlap, Mut Not Overlap With, Must Not Intersect and others. Did anyone know about this error? How to solve it?
Thank You
Nor Afizah
AbhishekRathi1
Dear Nor,
Kindly go through the below link for step by step procedure.
Creating a geodatabase topology to clean up data errors
This will hopefully solve your issue.
Thanks...
ChrisDonohue__GISP
There are a wide variety of things that can go awry with Topology that cause validation errors, ranging from high numbers of coincident polygons to large spatial extents.  I did a quick Google search and several issues were mentioned, though none were the same error as you experienced.
I'd contact ESRI Customer Support.  If you are in the United States, the number is:  909-793-3774.  They have more detailed information to go with the specific error and probably already have ideas on what needs to happen to resolve the issue.
Chris Donohue, GISP
Thanks. I'm from Malaysia.
