Error when enabling ORACLE database to enterprise database
2223
05-10-2014 08:27 AM
by Anonymous User
Not applicable
Original User: hanidraidi
When Enabling an ORACLE database to Enterprise database, an error occurs, but that doesn't happen with an SQL SERVER database. This is shown below with screenshots. I am using Oracle 11g.
Regards,
Hani
1-Enabling ORACLE database as enterprise database.
[ATTACH=CONFIG]33727[/ATTACH]
2- Enabling MS SQL Server database.
[ATTACH=CONFIG]33728[/ATTACH]
[ATTACH=CONFIG]33729[/ATTACH]
[ATTACH=CONFIG]33730[/ATTACH]
VinceAngelo
Esri Esteemed Contributor
You need to follow the install instructions quite closely for a correct install. What parameters did you use (less password, of course)? -V
by Anonymous User
Not applicable
Original User: asrujit
Are you using the "SDE" schema to Enable the Oracle database?
If you are planning to use the "Enable Enterprise Geodatabase" tool for the oracle database, you should have the Tablespace and "SDE" schema created/configured before running the tool.
The geodatabase administrator in Oracle:
http://resources.arcgis.com/en/help/main/10.1/index.html#//002n0000002q000000
Enable Enterprise Geodatabase (Data Management):
http://resources.arcgis.com/en/help/main/10.1/index.html#//001700000160000000
