Error: ???The number of points is less than required for feature???,
11894
03-05-2014 09:43 AM
by Anonymous User
Not applicable
Original User: [email protected]
I wanted to copy some features from file geodatabase layer to other enterprise geodatabase (SQL) layer but I got the error message below:
[ATTACH=CONFIG]31960[/ATTACH], [ATTACH=CONFIG]31961[/ATTACH], [ATTACH=CONFIG]31962[/ATTACH], [ATTACH=CONFIG]31963[/ATTACH]
What might be the issue here?
This problem is reported in many threads but with no robust solution
Thank you
Best
Jamal
JakeSkinner
Esri Esteemed Contributor
Try running the Check Geometry tool on the File Geodatabase feature class.  If there are errors, make a copy of the feature class and then run the Repair Geometry tool.
JakeSkinner
by Anonymous User
Not applicable
Original User: asrujit
Error:  The number of points is less than required for feature:
http://support.esri.com/cn/knowledgebase/techarticles/detail/33801
As Jake mentioned, the Check geometry should help you in identifying the problematic features.
JamalNUMAN
Legendary Contributor
Thanks Jake and Asrujit for the help. It works fine
[ATTACH=CONFIG]31987[/ATTACH], [ATTACH=CONFIG]31988[/ATTACH], [ATTACH=CONFIG]31989[/ATTACH], [ATTACH=CONFIG]31990[/ATTACH]
Jamal Numan
