???Error connecting to database as geodatabase admin???,
6939
01-29-2013 11:42 AM
by Anonymous User
Not applicable
Original User: [email protected]
I tried to create enterprise geodatabase (sql) from P1 machine to P2 machine but sounds not to work. I got the message below:
[ATTACH=CONFIG]21174[/ATTACH], [ATTACH=CONFIG]21175[/ATTACH]
What might be the issue?
Thank you
Best
Jamal
by Anonymous User
Not applicable
Original User: sshields
Jamal,
my first thought is that the password you are providing for the 'sde' user (geodatabase administrator) isn't working. If the sde login already exists on this server, the password you provide must match that of the existing login. If the sde login doesn't already exist and the tool creates this login, then the password must meet the password policy being used by SQL Server. You can find more information on the password policy here: http://msdn.microsoft.com/en-us/library/ms161959.aspx
-Shannon
JamalNUMAN
Legendary Contributor
Jamal,
-Shannon
Many thanks Shannon for the help,
What�??s confusing here that we are required to enter our password without being asked to confirm it and thus may easily forget what we have entered before.
On the other hand, in the sql one is asked to confirm this password
[ATTACH=CONFIG]21420[/ATTACH]
Best
Jamal
Jamal Numan
by Anonymous User
Not applicable
Original User: asrujit
This is something be design at the moment.
You can suggest a change in future release at the following site:
http://ideas.arcgis.com/
Its a great site with many wonderful ideas, which the ESRI team looks at for implementing in future versions.
Regards,
JamalNUMAN
Regards,
Many thanks Asrujit for the help,
I have already added it the ideas site as you have advised
https://c.na9.visual.force.com/apex/ideaList?c=09a300000004xET&sort=recent
all the best
Jamal
Jamal Numan
