Error adding mosiac dataset
2622
03-07-2013 06:20 AM
LorneDmitruk
This really a two part question.
1. I've trying to load an existing mosaic dataset into another mosaic dataset and have run into the following error:
[INDENT]2013-03-07T09:00:45.242: Loading raster datasets
2013-03-07T09:00:46.679: Completed crawling 1 data source items. Added 1 mosaic dataset items.
2013-03-07T09:00:46.695: Synchronizing crawled data source items
2013-03-07T09:08:10.628: Error: 80042024: Invalid mosaic dataset item. Could not update table using row buffer. [ID: 644, URI: 'C:\Documents and Settings\AppsLD\Application Data\Esri\Desktop10.1\ArcCatalog\imagery@GS_DEV.sde\IMAGERY.Alberta2012|-1']
2013-03-07T09:08:10.816: Completed synchronization: 1 items selected, 0 items synchronized.
[/INDENT]
I have successfully loaded other mosaics into the dataset. I have re-synced and analyzed the dataset I'm trying to load and there are no outstanding errors or issues with the mosaic.
2. When working with mosaic datasets and geoprocessing tool the errors are reporting with these 800xxx codes such as
[INDENT]Error: 80042024: Invalid mosaic dataset item. Could not update table using row buffer.
Error: 8004205f: No new mosaic dataset item was added.[/INDENT]
Are there more detailed listing for these error codes in the help documentation? I can't seem to find them anywhere.
Cheers!
WaelYahya
What is the reasons of having mosaic inside mosaic?
LorneDmitruk
In my case organization. I have imagery for a number of projects, however there are situations where I want to have all the imagery from all projects available in a single place for convenience of the users.
LorneDmitruk
I found this bug, NIM084428  listed on the support site. The current work around is to use a file GDB.
