Ok... more numpy lessons
Lets assume p_20 = 5 and p_80 = 15 (because I am too lazy to recalculate them)
Start with your search cursor or table to numpy array thing and get 'a' (I am cheating again, order isn't important eithr)
So array 'b' represents the 'result' from above... it need not be in order, but probably will be... doesn't matter.
Word of the day... np.in1d ... what it finds is all the occurrences in 'a' of what is in 'b'. It gives you a boolean array (0's and 1's)
Next thing you do is use 'np.where' to find out where the matches are, and if found give it the value in 'a' otherwise assign it that np.NaN thing I mentioned before. The results is where things match and where they don't they are 'nan' (not a number, but really...).
If you really, really must get it back to your table, then you can
>>> a = np.arange(20)
>>> a
array([ 0, 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16, 17,
18, 19])
>>> b = np.array([5,6,9,8,7,15,14,12,13,10,11])
>>> np.in1d(a,b)
array([0, 0, 0, 0, 0, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 1, 0, 0, 0, 0], dtype=bool)
>>> np.where(np.in1d(a, b), a, np.NaN)
array([ nan, nan, nan, nan, nan, 5.000, 6.000, 7.000, 8.000, 9.000,
10.000, 11.000, 12.000, 13.000, 14.000, 15.000, nan, nan, nan,
nan])
You can make a small table out of the result and use
ExtendTable—Help | ArcGIS for Desktop
to 'join' the resultant array back to the original table.
really its not hard
>>> outtable = np.zeros((len(result),), dtype=[('ID', 'int32'), ('Result', 'float64')])
>>> outtable['ID'] = np.arange(len(result))
>>> outtable['Result'] = result
>>> outtable
array([(0, nan), (1, nan), (2, nan), (3, nan), (4, nan), (5, 5.0), (6, 6.0),
(7, 7.0), (8, 8.0), (9, 9.0), (10, 10.0), (11, 11.0), (12, 12.0),
(13, 13.0), (14, 14.0), (15, 15.0), (16, nan), (17, nan), (18, nan),
(19, nan)],
dtype=[('ID', '<i4'), ('Result', '<f8')])
Then you just do the extend table thing. Now don't let all that magic in the above table scare you, it is basic numpy stuff. Pandas (available in ArcGIS PRO) is a gentler version of numpy and handles some of this if you can't understand the magic.
What I did
outtable ..... make an empty array of zeros, which is the lengthe of the 'result' array (some magic, the comma placement is paramount
The table will have 2 columns, one called 'ID' (integer) and the other 'Result' (double, floating point number since I used NaN
outtable['ID'] just assigned number from 0 to the end into this column
outtable['Result'] same thing, just used the 'result' array for this column
On an IThingy so I can't actually do the join back to the original table, if you really really must.
Otherwise you can save the result out to a file using several options... which I wont' get into here.
