Editor tracking vs. Historical Archive
1808
04-23-2012 12:10 PM
JenniferBorlick
We're looking for a solution to keep track of changes over time. Each change is going to be a permanent record. One of the solutions that has been floated to me is to make a pdf of the map when each change is made. I think there is a more efficient way to do it within the database.
At 10.0 there is historical archiving and being introduced in 10.1 is Editor Tracking. Are these features going to be related at all? The concerns that I have with Archiving are:
1) If you disable archiving, you break the archive off into a separate feature class that can't be rejoined to a new feature class.
2) If you disable archiving, the new feature classes aren't in the same feature dataset as the original feature class.
3) I have a dataset with several feature classes only 2 of which need to have an historical archive. From what I can see, I have to make an historical archive of the entire feature data set.
4) Seeing the Editor Tracking makes me nervous that esri is going to switch things up and discontinue archiving. My concern is that once I start using it, I may not be able to keep using it into the future and/or there will not be a way to port this information into new technology as time goes on.
I have no idea what to think of Editor Tracking because I haven't seen it and don't know what it's going to be able to do. Are you going to be able to pick a snapshot in time and view it? Are you going to be able to make something similar to Historical Markers? Is this going to be a more or less efficient way for me to track changes over time?
Any advice, discussion or better solution would be appreciated.
Jennifer
JakeSkinner
Esri Esteemed Contributor
Hi Jennifer,
Editor Tracking is different than archiving.  Through editor  tracking, ArcGIS can  automatically record the following information for  each feature or table record in a geodatabase dataset:
  • The name of the user who created it.
  • The date and time it  was created.
  • The name of the user who edited it.
  • The date and time it was last edited.
Take a look at the following link for more information.  You can see a short video of this functionality here (beginning at 1:35 of the demo).
JenniferBorlick
Jake,
Thank you for your response. Historical archiving it is. Now to figure out why I can't get it to work.
Jennifer
