Editor Tracking 10.1 Issues
2385
8
06-27-2012 09:12 AM
TedCronin
Enabling Editor Tracking in 10.1, prevents a user from accessing a 10.0 SDE Geodatabase with 10.0 Client.
CraigGillgrass
Ted,
This is by design.  Once a dataset is given 10.1 specific functionality; such as enabling Editor Tracking, 10.0 clients can no longer open that dataset; as the 10.0 client has no knowledge of the 10.1 specific functionality.
So, if you want to enable Editor Tracking, all clients accessing the data need to be 10.1 clients.
Craig
TedCronin
Disable fixes the issue.
CraigGillgrass
Ted,
Craig
TedCronin
This is what I figured out, thanks Craig.  Makes total sense now...:)
TedCronin
What doesn't make sense is where 10.0 and 10 SP1, support editor tracking , and SP2, SP3, SP4, and SP5 don't support editor tracking.
TedCronin
Another more serious issue, is after enabling editor tracking on a 10 sde database (then disabling it), the 10 access speeds have slowed to a crawl.  We started on 10.1 updates because of the issue.  10 minutes to select a record and have it show up in the Attributes window.  When relationship classes are in place, the table fields have a serious lag time.  Editing Anno has slowed to a crawl.
CraigGillgrass
Ted, to clarify, 10.0 Final and 10.0 SP1 do not support Editor Tracking. We added checks starting at SP2 to look for datasets with new functionality to prevent users from incorrectly opening them with an older release where the new functionality was not supported which could lead to data loss/corruption.
CraigGillgrass
Ted, we have not seen this issue and I can't reproduce it.  Can I ask you to contact Tech Support and open an incident so they can trouble shoot it and try and get a repro case for us to look at?
TedCronin
We upgraded our clients to 10.1, so the relationship class lag does not exisit anymore.  We still do see issues with Annotation inside of the GDB though, so perhaps that can be logged.  Our current approach is to use Feature cache, but we are seeing feature cache with anno at 10.1 is equal in speed to anno with no cache at 10.0 before we enabled editor tracking.  After enabling editor tracking the performance on 10 clients was really slow, too slow.  Basically the two operations are what pushed us forward to 10.1 clients sooner than expected. 😞
