editing polygon
1352
03-27-2013 10:40 AM
keremhepdiniz
After I close the polygon, I would like to change its vertices but I want to make it from vertices. For example I want to erase last to vertex and to continue from the last one when the polygon area open? Is there anyway to make it?
MarkBoucher
Honored Contributor
If I need to add onto a feature, I often will start a new one and when I'm done, I'll close the new, select it and the one I want to add it to and use the Edit>Merge tool to make them one feature  I use the "V" key to reveal the vertices and the snap options to make sure the added feature snaps to the last vertices in the previous feature.
keremhepdiniz
Thanks it helps me a lot. Is there anyway to  without editing a new polygon? After when we put the last vertex wrongly and close the polygon, go back and open the polygon again and continue from the last vertex?
Thank you...
MarkBoucher
Honored Contributor
The "Reshape Feature Tool" will let you change a selected polygon starting from anywhere. You select on the polygon you want to modify, click on the edge or vertex you want to start editing at, and reshape it. You have to close the reshape on the original polygon. This is probably as close to what you want as I can find. This will keep the attributes you may have entered for the polygon previously.
Add one vertex at a time. Select and then double click the polygon. The where you want to add a vertex, right click. I think you have to do this for ever new vertex you add.
I just discovered the "Replace" function. If I draw a polygon and finish it and then click the palet to start another polygon, select and right click on the existing polygon, there is an option to "Replace". This appears to do what you want, but two thing happen that you might not like. (1) The editing starts at the first vertex, not the last; and (2) it creates a new feature, it doesn't simply modify the first one. I'm not sure what happens to the attributes you may have entered for the polygon previously.
