editing ArcEditor created data in ArcView
1204
12-28-2011 12:22 PM
JB5
Hello,
I'm trying to find a convenient way to edit data (feature classes in feature datasets in file geodatabases) from an ArcEditor-created schema (make that ArcGIS for Desktop Standard) in ArcView (ArcGIS for Desktop Basic), all version 10.  I do not have ArcGIS Server.
Any suggestions?
Thank you in advance.
JeffWard
Honored Contributor
If the feature datasets contain topologies, networks, parcel fabrics etc. you won't be able to edit the feature classes in them using ArcView.  Maybe export them to a format that you can edit?
Jeff Ward
Summit County, Utah
JB5
Thanks for the reply.  I've removed topologies and relationship classes and no more problems.  However, you mention exporting - what format do you suggest?  Is there a way to incorporate changes into the original data?
JeffWard
Honored Contributor
There is a poster of what you can do with the different versions of ArcGIS Desktop here.  As to what format you export the data to and how to get it back to the original, I'm afraid I'm going to be no help there.  Sorry.
Jeff Ward
Summit County, Utah
