Drop down domain selection in attribute window vs attribute table
2645
7
05-30-2017 07:45 AM
SherieTaylor
Let's say I have a domain set up for the available road names, and that I'm editing the road name field in address points and looking for the road name of Greenwood Lane:
If I use the attribute window, when I start typing in the road name field, the minute I get to the Greenw, the road name selection jumps to Greenwood.
If I use the attribute table, when I start typing in the road name field, the minute I type Gr, the road name selection jumps to the R's because the last character I typed was an R.
Would be great if both worked the way the attribute window works.
JayantaPoddar
SherieTaylor
It's there!
Robert_LeClair
Esri Esteemed Contributor
So it's working as expected now?
SherieTaylor
No.  I was responding to the suggestion to add to ArcGIS Ideas.
Robert_LeClair
Understand - thx.  So according to this link, it's been implemented in ArcGIS Pro, Collector but not ArcMap.  I suspect it won't be implemented in ArcMap as most Desktop development is occurring in ArcGIS Pro.
Robert_LeClair
Are you using ArcMap or ArcGIS Pro?
SherieTaylor
ArcMap
