Domain creation problem
2741
03-17-2016 08:38 AM
LindaDeLay
I am using ArcCatalog ArcGIS 10.3.1 to create my domains. The process is not working. I add in the codes for the drop-down but when I ender accept and move to the next line to create the next domain name, the previous entries are not longer there. Is there a patch that I missed? Any solutions?
NeilAyres
Are the domains being added to a enterprise geodb like sql server or something. Do you have sufficient permissions?
LindaDeLay
No, just a File Geodatabase in prep for use in ArcGIS Collector. Not using subtypes but using the Coded list to create dropdown for attributes before I publish as a map service to ArcGIS Online.
Cheers
Linda S. DeLay, GISP
NeilAyres
Just double check the file permissions on the directory where the file geodb lives. Do you have write access?
LindaDeLay
Hi Neil:
The folder was read-only. I unchecked and will try this again. Was strange though that the first Domain I tried was successful and all others not. I’ll try again and report.
Thanks so much!
Linda
AdrianWelsh
MVP Honored Contributor
Hi Linda,
I am able to create domains in ArcGIS 10.3.1 without any issues. Have you followed the steps outlined at this webpage:
Exercise 3: Create subtypes and attribute domains—ArcGIS Help | ArcGIS for Desktop
