Does Data Interop Server 10.1 Extension support GeoMedia Access Warehouse 6.1 ?
887
11-04-2012 10:32 PM
ITAsset_Location_Team
I have an Spatial ETL process to download GeoMedia Access Warehouse 6.1 data into ArcGIS 10.1 ArcSDE. The ETL process works fine using python script running the ETL tool over Data Interop Desktop license.
Customer recently implemented this tool on another server that uses Data Interop Server Extension license v10.1. The tool started falling over. The FME log has following lines.
2012-11-05 18:01:07| 0.2| 0.0|INFORM|Loaded module 'FM0' from file 'C:\Program Files\Esri\Data Interoperability\plugins/FM0.dll'
2012-11-05 18:01:07| 0.2| 0.0|INFORM|FME API version of module 'FM0' matches current internal version (3.7 20111219)
2012-11-05 18:01:07| 0.2| 0.0|ERROR |Plugin 'FM0' was loaded, but a reader could not be created. Error was #913823: This format is not supported by this edition of FME
Customer has one Data Interop Desktop license and three Data Interop Server Extension license. I tested Server Extension using a sample WFS dataset as a source and it works ok. However, replacing the source dataset as GeoMedia Access Warehouse gives above error.
Does Data Interop Server 10.1 Extension support GeoMedia Access Warehouse 6.1 as a reader? Data Interop Desktop 10.1 Extension definitely supports GeoMedia Access Warehouse 6.1.
Regards,
Vish
VishApte
I just learnt that ArcGIS for Server being 64 bit application, GeoMedia Warehouse in Access format is not supported by Data Interop Extension for Server. This restriction is by FME.
I would like Esri to add note in http://www.esri.com/library/fliers/pdfs/data-interop-formats.pdf
Regards,
Vish
