Displaying Landsat ETM+
2283
07-02-2010 11:21 AM
EduardoMachicado
Hi there,
I'm an archaeologist trying to integrate Landsat ETM+ imagery to a regional survey in the Bolivian Amazon Basin. I've downloaded a file from the Global Land Cover Facility (http://glcf.umiacs.umd.edu)
that came in L1G format. So far I have followed the directions given at this web page "http://glcf.umiacs.umd.edu/library/guide/fileformat.shtml", and "http://glcf.umiacs.umd.edu//library/pdf/fileguide_l1g_arcgis.pdf" but I'm having problems with step 2, creating a World File.
According to the first link I should be able to find all the information needed in the metadata file, but there is SO MUCH information there that I don't know what should I copy to the hdr file and what should the the correct name of the hdr file. Without it I try to import the data, the files load but Im not able to see anything.
I am attaching the metadata file to this post. Could anyone give me hand making the world file? Maybe I'm doing something wrong? can anyone post a better tutorial on how to use Landsat ETM+ files in ArcMap 9.3?
Thanks a lot
JeffreyEvans
I am quite sympathetic. All the different file formats for remote sensing data can be quite a challenge. I would check if GeoTiff's are available for this scene. Historically GeoTiff was the format GLCF distributed data in. As far as I can tell here is what your header (hdr) file should look like for bands 1-5 and 7 (will need a separate hdr file for each band).
Image BSQ header file
nrows 6951
ncols 7871
nbands 1
nbits 8
layout bsq
skipbytes 0
ulxmap 210000.000
ulymap 8505000.000
xdim 30
ydim 30
Here is the info I extracted from the metadata for the reflectance bands (1-5 & 7).
nrows - PRODUCT_SAMPLES_REF = 7871 (Can't remember if this is row or col)
ncols - PRODUCT_LINES_REF = 6951 (Can't remember if this is row or col)
ulxmap - PRODUCT_UL_CORNER_MAPX = 210000.000 (Looks like UTM coord for zone -20)
ulymap - PRODUCT_UL_CORNER_MAPY = 8505000.000  (Looks like UTM coord for zone -20)
xdim - GRID_CELL_SIZE_REF = 30.000000
ydim - GRID_CELL_SIZE_REF = 30.000000
Here is where it gets tricky. The data is band-sequential so when you import bands 6H, 6L (thermal) and 8 (panchromatic) you will need to change the header info to reflect different row,column dimensions and cell resolutions. The suffix in the metadata for bands 1-5 & 7 - "REF", for 6L and 6H - "THM", and band 8 - "PAN".
As soon as you get this working I would export each band into a grid and then use MAKESTACK (available in raster calculator) to make an image stack for multispectral viewing.
EduardoMachicado
nrows 6951
ncols 7871
nbands 1
nbits 8
layout bsq
skipbytes 0
ulxmap 210000.000
ulymap 8505000.000
xdim 30
ydim 30
Here is where it gets tricky. The data is band-sequential so when you import bands 6H, 6L (thermal) and 8 (panchromatic) you will need to change the header info to reflect different row,column dimensions and cell resolutions. The suffix in the metadata for bands 1-5 & 7 - "REF", for 6L and 6L - "THM", and band 8 - "PAN".
Thank you so much for your help, I've been trying to figure this out by myself for long, since I'm right now down in the field. I created the hdr file but it doesnt seem is being read by ARCmap when I add the HDF file. Could it be because of naming convention? how do you relate a specific .hdr to the dataset?
so far, the file I created is named L712320070_07020000612_HDF.hdr, same name as the L712320070_07020000612_hdf.bsq.
am I missing something?
Thank you again.
EduardoMachicado
Ok, I figured it out, you need one file FOR EACH BAND literally.
Thank you so much for your help, the ETM+ panchromatic band is awesome, I've been working with 3 arc second STRMs for very long, I'm super excited about this.
Can anyone point me into a good resource to properly use the rest of the bands? I really want to learn how to work with this data.
Thanks
JeffreyEvans
You can perform some simple visualization by creating an image stack using the MAKESTACK command. This is a legacy Workstation ArcInfo command but is available in Spatial Analyst's raster calculator. The usage would look like this (no spaces in path name):
MAKESTACK C:\YourPath\stackname LIST C:\YourPath\band1 C:\YourPath\band2 ...
This will create a dataset that has all of your bands contained within. When you add this image stack to ArcMap you get an RGB color composite. You can change which color gun a band is assigned to in the datasets properties.
Here is a nice introduction to multispectral band composites
http://www.crisp.nus.edu.sg/~research/tutorial/opt_int.htm
For actual classification there are some tools available in ArcGIS (i.e., Maximum Likelihood Classification). However, if you are interested in classification I would recommend taking a look at a the following open source (free) remote sensing software.
MultiSpec (Documentation has nice introduction to image classification)
http://cobweb.ecn.purdue.edu/~biehl/MultiSpec/
OSSIM
http://www.ossim.org/OSSIM/OSSIM_Home.html
ILWIS
http://www.itc.nl/Pub/research/Research_output/ILWIS_-_Remote_Sensing_and_GIS_software.html
SPRING
http://www.dpi.inpe.br/spring/english/
You may also be interested in BASP (The Bonn Archaeological Software Package)
http://super3.arcl.ed.ac.uk/baspmirror/basp.html
ToreBorvik
do you have access to envi / envi ex? you can open the header file directly there to get the information you need..
