Disabling Edit Vertices Toolbar
684
04-30-2013 11:55 AM
lisadavis
I do parcel edits daily and until today have never had the edit vertices toolbar popup when I start to edit a parcel or line. I have not updated anything on my computer nor on ArcMap today or yesterday. I have tried everything I know to try to turn it off so that I can continue to edit as I have previously done.  I have unchecked it on the editor options and turned it off on the toolbar list on the customize tab.  My ArcMap project is running extra slow also today and I assume that this toolbar has something to do with this also. Typically, when I click a parcel or line, the item will be selected almost immediately, but today when I select a parcel or line the project just sits and spins.
RobertBorchert
Honored Contributor
Start your session.
Use the customize toolbars to add the Edit Vertices to your MXD
Then simply dock it somewhere.  It is a default thing for it to pop up.  If you have tried doing things to it and it is spinning try resetting that toolbar first.  Then add it and dock it.
