Difference between sde.st_within and sde.st_relation_operators.st_within_f
1077
02-08-2013 11:11 AM
TonyGroeneveld
I was using the following in an Oracle where clause:
[INDENT]sde.st_within(op.shape, z.shape) = 1[/INDENT]
Most of the time the statement would work but occasionally I would either get a 'Error generating shape (shape2)' or a 'Error changing coordref (shape2)' error
After much frustration I changed the statement to sde.st_relation_operators.st_within_f.
So far no errors.
Can anyone explain the differences between the two ways to call the st_within function?
ForrestJones
Hi Tony,
It sounds like you might be hitting an issue. The "_f" functions are for use with stored procedures and/or triggers. See this KB article for more details:
HowTo:  Leverage st_geometry operators in Oracle's PL/SQL
Would you be able to open an incident with technical support please, so we can figure out what the problem is?
