Using 10.1, ArcCatalog, personal geodatabase with two feature datasets.
In one of the feature datasets I am able to delete the dataset or any of the feature classes within that dataset but when I try to delete the other feature dataset or a feature class in it the Delete is grayed out. Is my GDB corrupted or a bug, or??? There isn't a lock on the database either when I'm trying to do this.
This is all occurring in the BISDM3.mdb I downloaded from Esri.
Solved! Go to Solution.
If I'm understanding what I'm being told, this was created with Network Analyst, which is different than a geometric network that you only need ArcInfo to create, and that's why I can't delete it.
Since I don't have the Network Analyst extension (and I've never used it), I'll just have to do the work around to get rid of that feature dataset.
Thanks for your help guys!
I am good to go guys, thanks again for your help.
