Delete Identical with ArcEditor?
2242
12-10-2012 07:54 AM
by Anonymous User
Not applicable
Original User: alnesbit
Hello all,
I just realized there is a cool new tool called Delete Identical that would work great for me right now. Unfortunately I only have ArcEditor, not ArcInfo. Soooo does anyone have a way I could do this functionality with ArcEditor? I used to use a sql query for duplicate records in a feature class table and I can still use that, but it selects all of them, then I have to go through and delete all but one of the duplicate records.
Just wondering.
ThanielG
Have you tried this below?  I used it in Arc 9.x so obviously haven't used it in a while
http://support.esri.com/en/knowledgebase/techarticles/detail/38700
ThanielG
by Anonymous User
Not applicable
That's it, thank you. and this forum helped (which for some reason didn't come up when I searched the forums the other day): http://forums.arcgis.com/threads/4021-ArcGIS-10-Pre-Release-finding-duplicates
ThanielG
Cool beans. Good luck.
