Data Loading Error
4283
04-05-2016 11:59 AM
NatalieLepsky
We've been creating feature classes in new Enterprise GIS based on DB2 database. The new feature classes are created based on importing/loading data from the existing feature classes on different database. We encountered a problem with data loading when we imported a feature class with two fields set as double with precision 31 and scale 8 in the old environment, but updated the precision and scale to 9 and 5 respectively in the new environment. We get the consistent error and can't load the data.
Underlying DBMS error [[IBM][CLI Driver]CLI0111E Numeric value out of range. SQLSTATE=22003::22003]
Any thoughts please?
George_Thompson
Esri Notable Contributor
Hi Natalie,
Is it possible that the old field has some numbers that are "outside" the precision 9 and scale 5 settings for the new geodatabase field?
Is the old geodatabase on DB2 also?
What version are the enterprise geodatabases? (old and new)
Geodatabase
--- George T.
NatalieLepsky
George,
Thanks for your reply!
Both databases are db2. Arcgis is 10.1.
I am not sure about numbers with precision outside 9, but I was able to load the same feature class in my personal geodatabase on the same db2 tables space without a problem. But can't copy it or load it...
Sent from my iPhone
