Data Loading Error - [Complex Data Loader]
1062
08-05-2011 10:51 PM
SathiaG
Hi..
Following is the errror message we are getting all of a sudden in our regular process of data loading via Complex Data Loader in ArcMap in a dummy version. It freezes at right after the moment i give finish after setting the source etc and throw the error msg after quite sometime.
Could not load data from the source. If you can correct the problem, press the refresh button to reload the data. Possible problems can include bad network connection, invalid field etc.
Logfile not found
As far as we have checked, it doesnt have bad network connection or invalid field. And this happens particularly to one Feature Class. All other classes are loaded sucessfully. This Feature Class doesnt have any special characters in the name or in any field name too.
The DB is ArcFM configured, and it has been converted to ESRI objects before loading.
S/W we use are,
ArcGIS 9.3.1 SP1, SP2
ArcFM Solution 9.3.1.5881 SP1
ArcSDE 9.3.1 SP1 SP2
DB Server: Linux - Oracle Database 11g Enterprise Edition Release 11.2.0.1.0 - 64bit Production
