Data Interoperability Extension - KML Extended Data
3331
09-16-2010 04:29 PM
PatLandrum
I have a KML that's being updated every few minutes and posted to a URL.  The KML includes ExtendedData, which contains Changeable Message Sign (CMS) information (travel times, alerts, etc.).  I can connect using the Data Interoperability extension through ArcCatalog (10), add the KML to an MXD and publish to a map service, and add to a FlexViewer app.
The ExtendedData elements are the issue - they're not included.  I've also been unsuccessful in converting/tranferring the ExtendedData using the Data Interoperability (FME) Workbench.  I can visualize the input KML and all needed attributes, but I've been unable to get them over into a feature class.
Anyone running into similar problems?  I've also tried all (that I know of) KML to shape translators  - no problem converting the points - but the ExtendedData isn't coming over.
URL for a sample of the CMS  http://www.dot.ca.gov/research/its/kml/cms/cmsD11.kml
Any feedback is appreciated.
BruceHarold
Esri Frequent Contributor
Hi Pat
In your workbench, make sure to expose additional attributes for extended data.
The parameters dialog for the KML reader has a control "Additional Attributes to Expose" which brings up the dialog in my first screengrab.
Then in your workbech, expose and explode the list attribute - you'll get name and value attributes.
You'll have to do more work to pivot the exploded features back into a single part per kml_id.
Regards
