Cut polygon into multiple pieces
3033
10-05-2011 01:34 PM
timfluhr
Hi all.
I'm having trouble cutting a polygon into multiple pieces.  I have a shapefile of a TIF district that I would like to break into 4 or 5 sections.  I select the polygon for editing but when I use the 'cut polygon' tool to split the polygon, part of the polygon disappears.
I can't seem to figure this out.  Can anyone point me in the right direction?
Thanks.
Robert_LeClair
Esri Esteemed Contributor
Tim - question for you - are you using the Cut Polygon tool in a layer generated from the "Create Layer from Selected Features" command?  If so, there's a NIM040435 that addresses this particular issue with no resolution other than not creating a layer from selected features.
Robert LeClair
Esri-Denver
DanLee
by Esri Regular Contributor
If you want to split the polygon into rectangular shapes, the following tools might be helpful:
- Create Fishnet tool gives you grid-like polygons based on your specifications.
- Split tool splits your data using the fishnet polygons.
Regards,
timfluhr
Esri-Denver
Robert -- Yes!  I selected a few TIFs from a larger file and made a layer.  I guess I can work from the original layer.  I thought I was going crazy.  Thanks!
-tim
JeffWard
Honored Contributor
Are you sure you weren't using the Reshape Polygon tool?
Jeff Ward
Summit County, Utah
