customizing locator - adding new address suffix doesn't work
1084
10-05-2011 06:06 AM
JohnSchwob
I am in ArcView 10.  I have downloaded and read the ESRI Geocoding Technical Paper on "Customizing Locators in ArcGIS 10".
My address locator has a suffix "Acr" that I want to match whenever the address ends with "Acres".  I opened the USAddress.lot.xml file in notepad. I went to the section where you define Street Types.  I added the following code to the file.
<def name="_acr" is_alias_list="true">
   <alt>Acr</alt>
   <alt>Acres</alt>
</def>
At the bottom of this section of the code I added
<def name="suf_type">
   <alt ref="_acr"/>
I save the file and when I geocode a set of addresses, it didn't match a street which ended in "Acres" to the Address Locator which for this address uses "Acr",
A related question, how do I know that the geocoding process is using the newly revised USAddress.lot.xml file.  The file is located on my computer in C:\ESRI_ArcView_10\Desktop10.0\Locators.  That is where I found the file when I searched for it.  This is the first change that I have made to the USAddress.lot.xml file.
I would appreciate someone's help.
John Schwob
Office of Planning
Archdiocese of St. Louis
JeffWard
Honored Contributor
You might need to rebuild the locator.  Right click on the locator and choose "Rebuild".
I hope that helps.
Jeff Ward
Summit County, Utah
JohnSchwob
Jeff,
Thanks for your response.  Unfortunately rebuilding didn't work.  It's as if any changes I make to the  USAddress.lot.xml file are just ignored.  I still need to try to find out where ArcMap knows to find this file.  I want to make sure it is in fact using that file.  That is still a mystery to me.
John Schwob
BradNiemand
Once you edit the USAddress.lot.xml you will need to re-create the locator, not rebuild it.
ArcGIS always looks for the USAddress.lot.xml file in the ArcGIS Install directory in the locators folder.
Brad
