Creating Oracle enterprise: ???failed to insert a value to the geodatabase system???,
3346
5
01-10-2013 10:13 PM
by Anonymous User
Not applicable
Original User: Jamal432@gmail.com
Creating Oracle enterprise: �??failed to insert a value to the geodatabase system�?�
As I�??m trying to �??create enterprise geodatabase�?� based on Oracle platform, I got the message below:
[ATTACH=CONFIG]20638[/ATTACH]
I�??ve installed the oracle database (Oracle_Database_11g_R2_64bits) of desktop class and client side (Oracle_Database_Instance_11g_R2_Client) on the same machine. The path in the environment system/variable system is provided with the path of the client instance.
[ATTACH=CONFIG]20639[/ATTACH]
What might be the reason?
Thank you for the answer
Best
Jamal
by Anonymous User
Not applicable
Original User: vangelo
Are you creating a number of user-schema geodatabases, using 10.1 SP1?   I'm trying
to create a reproducible case of this, to submit it to Tech Support.  If you can reproduce
this error, please contact Tech Support.
- V
ForrestJones
Hi Jamal,
Is there any more information in the sde_setup.log mentioned in the create enterprise geodatabase output shown in your first attachment?
by Anonymous User
Not applicable
Hi Jamal,
Thank you Vince Fojo for the contribution.
What I did is formatting the machine. And now it is working perfect. Instead, I got the message below:
�??The ST_Geometry shape library path may be invalid, or the EXTPROC is not configured correctly in the Oracle instance. [ (Unable to determine current version of ST_SHAPELIB. The latest ST_GEOMETRY and dependent libraries need to be copied to the correct software location. Refer to the ArcGIS help topics for more details�?�
[ATTACH=CONFIG]20668[/ATTACH]
What might be the issue?
Best
Jamal
ForrestJones
Hi Jamal,
It looks like the create enterprise geodatabase is now successful. What you are seeing is a warning about configuring the extproc to run sql against st_geometry objects.
See this web help topic for more information:
ArcGIS Documentation: Configuring the Oracle listener to use ST_Geometry and ST_Raster
by Anonymous User
Not applicable
Hi Jamal,
Thank you Fojo for the prompt answer.
I had a look on the valuable link that you have sent but couldn�??t figure out precisely the impact of such warning on the database and its behaviour
Best
Jamal
