Creating intersections in line shapefile
1021
08-09-2011 10:32 AM
PeteLarson
Hello,
I have just traced out a road map from an image manually for use in Network Analyst. It does not work with my data.
I noticed that some lines do not connect with others. Is there any way to bulk snap lines to the nearest line?
Please help,
Pete
DanLee
by Esri Regular Contributor
If you are using ArcGIS 10 with an ArcEditor license, you can try the Snap tool in Editing toolbox. Hope that helps.
Regards,
CarlBeyerhelm
Another option is to create a topology rule for "must not have dangles", and then mass TRIM and EXTEND from the Topology Error Inspector using a reasonable search radius.  TRIM and EXTEND will insure original directionality is preserved.  Planarize lines if an actual intersection (split line) is required.
