Creating Domains and Subtypes: Subtypes Field Empty
2568
06-23-2013 09:35 PM
KwadwoKyeremateng
Hello Guys,
I have to build a geodatabase that allow users to pick entries from a particular coded value for a domain, and then based on the selected coded value, select another value in the next field. The workflow is like this, from a selected Region, the user will have the option to select only Districts for the select Region. Domain and Subtypes should do the trick for me but its not working for me. For example:
Domain
Region
Coded Values
Medway
Chatham
Subtypes
For Medway:
Rochester
Gillingham
For Chatham:
Newington
Key Street
In the geodatabase, I've set up the domain Region and have my two coded values. However when i go to the polygon feature class, and i want to create subtypes for each of the coded values, the subtype field list is empty! Why dont i have the domain 'Region' in the Subtype field? Again, if am on the wrong path, can someone re-direct me?
Kind regards
Kwadwo
KwadwoKyeremateng
Guys,
I found the answer. Because I'd set the 'Region' field to be 'Text' field type, Subtype Field could not list it (for some funny reason, its as though its suppose to pick only 'Interger/Numerical' fields from ones attribute table). Anyhow, then again, I had to create a domain for each of the 'Districts' in the File Geodatabase. And so there was a domain called 'Medway' with coded values; Rochester and Gillingham, and another Domain called 'Chatham' with coded values; Newington and Key Street....... etc.
In the feature class polygon, under the subtypes tab, I selected the Region field (which is not an interger field) from the drop list in Subtype Field and started listing the different Regions, that is, code= 0 and Description= Medway; code =1 and Description=Chatham etc.
Then for the Default Values and Domains section: for each Region, say Medway, I would select the corresponding 'Domain' from the Domain drop list.
And so now, when i start editing my feature class, i get to the attribute field and from the drop down i select my Region from the Region list, the next field 'District' automatically becomes populated with the Districts of the Region I had earlier selected.
I hope this helps someone out there as it did to me.
Many thanks
Kwadwo
