Creating DEMs from LIDAR multipoints
12081
19
07-01-2014 09:07 AM
ScottLouque
I have LIDAR multipoints and would like to group them into tiles and then make DEMs out of the tiles. All my multipoints are stored in a GDB format. Can anybody put me on the right path on how to accomplish this? This is my first time fooling with LIDAR data and I want to learn about elevation data.
ArthurCrawford
Hi Scott,
I would suggest using the Topo To Raster tool instead.   The interpolation procedure has been designed to take advantage of the types of input data commonly available and the known characteristics of elevation surfaces. This method uses an iterative finite difference interpolation technique.
Topo To Raster Tool Help:
http://resources.arcgis.com/en/help/main/10.2/index.html#/Topo_to_Raster/009z0000006s000000/
Description of Topo To Raster:
http://resources.arcgis.com/en/help/main/10.2/index.html#/How_Topo_to_Raster_works/009z0000007m00000...
When I do this operation, I like to set it up in model builder with the polygon tiles going through an iterator feature selection.    It selects the points based of a buffer of the tile to get points outside your tile (say 100m) and then inputs them to the Topo To Raster Tool and use a Clip Raster with the polygon tile on the output to get it back to the original tile size.    This step is important as your DEM tiles will not match each otherwise.
On converting to USGS DEM format, it's does not look like we support that.
http://resources.arcgis.com/en/help/main/10.2/index.html#//009t0000000q000000
Arthur Crawford
ScottLouque
Will give it a try! Thanks Author
GordonSumerling
Scott,
take a look at the lidar white paper from Esri. It predates the las data set but covers your questions about multipoints to terrain.
http://www.esri.com/library/whitepapers/pdfs/lidar-analysis-forestry-10.pdf
hope this helps
Gordon
IanMurray
Honored Contributor
Gordon, this topic got remade after the transfer to GeoNET, and was answered on this thread
Would like to get rasters into a USGS .dem file.
Thanks for the extra info though!
SteveSnow
Esri Alum
Hi Scott,
I hope this helps.
try page 13 below multipoint to terrain
check out this lab our team made to address multipoint in 10.2
A quick how to we made on working with Lidar in ArcGIS
http://www.esri.com/~/media/files/pdfs/library/workshops/arcgis102-lidar-workshop.pdf
Good luck,
Steve
ScottLouque
Thanks so much for the info guys! Since I've started working with the multipoints which we accquired from a vendor, I've figured out how to bring them into a feature class and convert them to a raster dataset, then bring the raster images into global mapper and export them out to a DEM file. Which is what I was trying to figure out when I started this thread. But I've also learned how to create las files in Global Mapper and create a terrain dataset from the multipoints.
Thanks for all the help!
SteveSnow
Esri Alum
Good luck scott, sounds like a lot of work.
JohannesBierer
Has someone tested this tool?
LASzip | rapidlasso GmbH
Should be quite fast?
IanMurray
Honored Contributor
I've used LASTOOLs quite a bit and they can be very useful.
JamesWeakland
