Would like to get rasters into a USGS .dem file.
5089
07-15-2014 06:10 PM
ScottLouque
I started with a collection of multipoints and was able to import them as panels into a file geodatabase. From there I was able to create terrain datasets out of each panel. Then used the Terrain to Raster tool in 3d Analysis tools to create Rasters out of each panel. Now I would like to have these raster to be .dem files. Is there anyway in ArcMap or Global Mapper to convert these to .dem file?
IanMurray
Honored Contributor
THere should be a way in Global Mapper(I know this is a bit of a carry over from that other thread you asked on).  The Export DEM command allows the user to export any loaded elevation grid data sets to a native format USGS DEM file.
Global Mapper User's Manual
Alternatively, I found a relevant Stack Exchange thread that you might be interested in if the Global Mapper solution doesn't work out.
arcgis 10.0 - Can I convert ESRI Grid (DEM) raster to USGS DEM? - Geographic Information Systems Sta...
Hope this helps
IanMurray
Honored Contributor
Hope this helps
ScottLouque
Thanks Ian Murray! I was able to export my rasters out to a dem in Global Mapper. I think that is going to work.
Thanks again!
IanMurray
Honored Contributor
You are quite welcome, glad that worked out for you.
