Create Polygon from points (as centroids)
4016
05-09-2012 11:32 PM
KrupaliVijaykar
I have a point layer of village data.
I need to convert it to polygon, such that each polygon has only one point (as its centroid).
We can create a polygon using 3 points, but i need a method to create one polygon using only one point...
Kindly advice.
Regards,
KVijaykar
JoeBorgione
MarcinGasior
I'm not sure if it's what you mean...
When you Buffer the points, you'll get circles with a village point as a centroid.
KrupaliVijaykar
Thanks for the reply..
I however wish to create approximate village boundary using the point data.. I have population data attached to each point, so maybe using that as numeric value, is there any method to create polygons???
JoeBorgione
Take a look at Create Thiessen Polygons.
KrupaliVijaykar
thanks a lotttt
