Create Enterprise GeoDatabase Error on PostGreSQL
4750
11
05-21-2017 09:05 PM
SignalGroup
I am running Create Enterprise GeoDatabase tool on PostgreSQL Database on windows ,this tool is throwing above error
venkateswarlunittala
Amazon RDS Postgres Enable Gerodatabase tool with Postgis 2.2.5
ArcGIS 10.4.1
I am getting below error any help is appreciated.
Start Time: Fri Jun 23 06:39:09 2017
Validated authorization file.
User has required privileges for geodatabase setup.
XML support is enabled for the database instance.
Connected RDBMS instance is setup for Esri spatial type configuration.
Failed to create stored procedures in the geodatabase. Error (-42)
DBMS error code: -42
ERROR: too many parameters specified for RAISE
CONTEXT: compilation of PL/pgSQL function "sde_layer_def_change_table_name" near line 20
SQL state: 42601
See the setup log in the following location for additional error information:
C:\Users\ADMINI~1\AppData\Local\Temp\2\sde_setup.log
Could not create geodatabase tables and stored procedures.
Failed to execute (EnableEnterpriseGeodatabase).
Failed at Fri Jun 23 06:39:34 2017 (Elapsed Time: 25.13 seconds)
Venkat
VinceAngelo
Esri Esteemed Contributor
Please ask a new question instead of adding on to an existing thread with a different environment. As stated in this thread, it's always critical to specify, in  the question, the exact release of the database to which you are connecting.
