Correcting building height using Lidar data
1463
07-11-2017 02:43 AM
LieyaIemran
I received a data of building footprint with height, which was extracted from classified lidar data. However, I noticed that the height of some buildings data which were under a tree would have incorrect height, where the building height is the average height of the tree and the building.
So, is there a better way that i can use to edit those incorrect height rather than manually edit it? since the I have around 67K records. Is it better & faster if I extract a new height?
I would be grateful if anyone could help to suggest the quickest way to correct the building height. Thank you.
Lieya
DanPatterson_Retired
Are all 67K wrong?
LieyaIemran
No, not all of the height is wrong. mostly those which under the trees.
