copying a view
1354
07-04-2013 02:26 AM
by Anonymous User
Not applicable
Original User: haniu_ntt
I want to copy a view to FGDB or PGDB. Both failed.
Why ? Cant view be copied ?
Thanks
[SQL Server 2005, ArcSDE 10.0]
by Anonymous User
Not applicable
Original User: crafty762
I am not certain why this is failing, but one thing you could do is export your view to an Excel spreadsheet and then import it into the FGDB or PGDB after the fact.  This method might work well if you only need to do this a few times here and there.  Another option is to create an empty table in your FGDB or PGDB with the correct field definitions and then load the data values in using the Simple Data Loader in ArcCatalog.
HaniuHokkaido
yes.thanks. the load works fine. i am just wondering why the copying fails ?
thanks again
