Copy Geodatabase
3889
04-22-2013 12:17 PM
CliffParker
Is there an easy way to copy an entire sde geodatabase to a file or personal geodatabase?
The only way I've been able to successfully copy is by exporting to xml and then importing that same xml into my new geodatabase.
This works but can take quite some time depending on how big the gdb is.
There must be a quicker / simpler way.
RobertBorchert
Honored Contributor
Create the new geodatabase in either file or personal in ArcCatalog
open a second ArcCatalog
One window on the old one on the new.
Simple grab and drag feature datasets from SDE to the new database.
If you SDE is large it works best to only grab a few at a time. But you can try it first with the whole thing.
RobertBorchert
Honored Contributor
FrédéricPRALLY
Hi PMcaparker,
Maybe you can take a look at this KB article below:
http://support.esri.com/en/knowledgebase/techarticles/detail/40831
Have a great day,
Fred
JoshuaBixby
MVP Esteemed Contributor
+1, automation is the way to go with tasks like this one.
