Converting .tfw to layout shp or dwg file
6363
01-01-2013 10:59 PM
MohanGovindaraj1
Hello all,
I have around 1800 tiff and tfw files. Is there anyway to batch convert this into layout(outer extents of tiff) shp or dwg file?
Thanks...
JakeSkinner
Esri Esteemed Contributor
Are you looking to get a shapefile/dwg for each individual TIFF's extent, or one shapefile/dwg for a mosaic of the TIFFs?
MohanGovindaraj1
Thanks Jake.
I am looking for shp/dwg of each individual tiff's extent.
JakeSkinner
Hi Mohan,
If you have the 3D Analyst extension, you can use the Raster Domain tool to create a polygon or polyline footprint of each raster.  Since you have 1800 TIFFs it would be best to run this tool using a python script where you can iterate through each raster.  Here is an example:
import arcpy
from arcpy import env
env.workspace = r"C:\data\raster\TIFF"
arcpy.CheckOutExtension("3D")
for raster in arcpy.ListRasters("*", "TIF"):
    arcpy.RasterDomain_3d(raster, raster.split(".")[0] + ".shp", "POLYGON")
If you do not have the 3D Analyst extension, and you are using ArcGIS 10.x, you can create a mosaic dataset of all the TIFFs.  When you create a mosaic dataset, a Footprint layer is created of all the rasters.  You can then iterate through this layer exporting the footprint of each raster.  Here is an example:
import arcpy
env.workspace = r"C:\DATA\RASTER\TIFF\MosaicDataset.gdb"
env.overwriteOutput = 1
arcpy.MakeMosaicLayer_management("Philadelphia", "MosaicLayer")
rows = arcpy.SearchCursor("MosaicLayer/Footprint")
for row in rows:
    OID = row.OBJECTID
    arcpy.SelectLayerByAttribute_management("MosaicLayer/Footprint", "NEW_SELECTION", "OBJECTID = " + str(OID))
    arcpy.CopyFeatures_management("MosaicLayer/Footprint", r"C:\data\raster\tiff" + "\\" + row.Name + ".shp")
del row, rows
MohanGovindaraj1
The first one works very fine.
