Convert String to Double
49465
14
05-22-2012 11:22 AM
TimHayes
In a Feature Class Attribute Table, I have data in a column that is of string data type and need to convert it to a double data type. I have already added an empty column with a double data type on which I can use the Field Calculator.
What is the best way to go about this?
MichaelRobb
Honored Contributor
It should work fine if the featurelcass is in a FileGeodatabase. A Shapefile will not work for what you are looking for as I have mentioned.
Id Import the shapefile into a FileGeodatabase and then your desired <null> will work... and so would the script.
GoldenJiang
What's the difference if I save a featureclass in a folder or save it in a FileGeodatabase?
I have been saving data to folders all the time. Hope that doesn't affect my yield data.
curtvprice
Datasets saved to a folder from ArcGIS tool output are saved in shapefile (feature classes) and .dbf table format.
Geoprocessing considerations for shapefile output—Help | ArcGIS Desktop
Geoprocessing considerations for shapefile output—Appendices | ArcGIS Desktop   (Pro)
MichaelRobb2
Well this is weird.  For a minute I thought I had forgotten how to code in the last 7 years, but quickly realised that my name sake had just helped me out, thanks!!
MichaelRobb
Honored Contributor
Alternatively, you can use the "Show Codeblock" in the field calculator and then use
Output = CDbl( [lFIELDNAME])
[Field] = Output
CDbl converts the string to double.
You can then add more items such as Replace as well to remove items such as periods or decimals if need be
e.g.
Output = CDbl( Replace([FIELDNAME],"."," "))
