convert points between grid and true north
1522
03-28-2012 03:22 PM
AmyKlug
Is there a way to convert point data from grid north to true north and vice versa if you know the grid convergence value?
AmyKlug
update: will use cogo.
AmyKlug
so i dont think i can use cogo because i only have a grid convergence number in degrees and the points in true north. i dont have a distance to enter. I tried to use a trangles to get distances but I dont have enough sides for the triangle with the grid convergence angle because it's not a right triangle.
any ideas?
MariaVolodina
any ideas?
Have you found solution for the problem?
AmyKlug
No I have not. I'm not working on that anymore but am still curious on how to do this
