Convert Oracle SDE export format to shapefile?
835
09-05-2012 03:04 PM
TroyPayne
Is there any way to convert an export file from Oracle SDE (GDB) to a shapefile or other format that's usable by ArcGIS desktop using only desktop tools?  I only have access to ArcGIS 10.0 for desktop (not ArcSDE or server) and have an export file that I'd like to use.
VinceAngelo
Esri Esteemed Contributor
The only possible access would be through 'sdexinfo -o list -a -s', and then
you'd need to parse the resulting ASCII stream.
- V
